Bandwidth Based on Endpoints
Patrick Sparkman
Is it possible to have all calls between an MCU and TCS use a set bandwidth (2048kbps), however for any calls with either the MCU or TCS between any other endpoints that aren't those two devices will use a set bandwidth (768kbps).  We utilize TMS and a VCS in our infrastructure.
Examples:
MCU <> TCS - 2048kbps
MCU <> Endpoints - 768kbps
TCS <> Endpoints - 768kbps
Any help in making this possible would be great!  Thanks.
2 Accepted Solutions
Martin Koch
Do you use a VCS? Then check the admin guide for bandwidth management: links / pipes
guess that would be the best place.
You can also have different recording aliases with different bandwidth settings on the TCS.
Default call rate setting on the MCU + define the TCS as an "Endpoint" with 2mbit/s on the MCU
and/or set a default call rate on the endpoints to 768kbit/s or something like that.
But I would go with the links / pipes model
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Administrator_Guide_X7-1.pdf  (pages 202..)
Hi Patrick,
Do you want to use 768kbps on all the endpoints to call anyone in the network i.e TMS,MCU, other endpoints, etc. If yes, then I believe that the best solution would be to go into the endpoint configuration and limit the call rate from there. You can do that using the following command :
xConfiguration Conference 1 DefaultCall Rate: 768
xConfiguration Conference 1 MaxTransmitCallRate: 768
xConfiguration Conference 1 MaxReceiveCallRate: 768
Doing so would allow you not to change the configurations on the TMS or VCS and the calls from the endpoints would go at this rate.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Martin Koch
Thanks, I'll look into it.
From my understanding of VCS Links/Pipes I would need to add the MCU and TCS into their own subzone and set their bandwidth there to be 2048kbps.  What would I set the MCU and TMS to use as far as bandwidth for these two devices, and for our TMS as far as scheduling would go?
Hi Patrick,
Mubashshir Akhtar
Thanks, I haven't had a chance to implement either option, but it is pointing me in the right direction as both scenarios will work.  At least I know I can achieve what I'm looking for, and ways to go about it.
