Bandwidth is not going beyond 384kbps.
alok.shukla21
I have installed CUCM 11.5 and configured DX80 with it. I The video quality is very low as the bandwidth is not going beyond 384kbps.
Kindly suggest if it is possible to increase it to 2mbps.
Thanks in advance.
Patrick Sparkman
Check your Location and Region settings within CUCM, it sounds as if the bandwidth settings for one of those is limiting the call to 384kbps.
dpetrovi
Hi Alok,
Let me move this post to Telepresence community. This community is for Cisco WebEx Meetings Server and Cisco Unified MeetingPlace products and is not observed by TP experts.
I hope this will get you the answers you need faster.
Kind regards,
-Dejan
Thanks Dejan for the help.
Patrick Sparkman
alok.shukla21
Yes its working now. In the Region settings, I have changed the value of "Max Bit Rate for Video Calls" to upto 6Mbps.
Thanks.
