Biggest Cisco Telepresence System on Wheel Base?
What is the biggest Cisco telepresence system on a wheel base?
In need of a telepresence system that can be easily moved between different boardrooms on the same floor. Beacuse of the size of the boardrooms we need the biggest possible display screen on wheels.
Thanks in advance
jdedell12
Level 5
Level 5
Kelvin,
There are a lot of cart options out there for both single and dual monitor options.  You could then add an SX20 and have a portable solution of whatever size you need.  Try Googling monitor carts stands and see if you find a cart to meet your needs.
John
As John has said above, you just need a capable trolley and put whatever codec you desire on to it as well.
We've done this before with the All-Metal-Magic and Gilkon Axis trolleys before.  The Gilkon ones are good as they have a lockable cabinet on the bottom to hold the codec and any other required equipment.
Note: they're links to Australian web sites, but you should be able to source something similar in your location.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
