Bookings List
Chad Reynoldson
My customer uses Exchange to schedule rooms and tells me that the SX80 end-point can prompt the user to connect to the scheduled booking.
1) How do I mimic this functionality on an AMX system using the API (i.e. put up the booking prompt on a touch panel at the scheduled time)?
2) How do I allow the user to "Connect" to that booking being prompted?
Thanks in advance,
Chad
sunr
Hello Chad
Please refer the answers inline.
ans: I am afraid this is not possible. Since the endpoint/system should be managed by TMS . In first place you cannot schedule the systems if it is not managed by TMS. TMS pushes OBTP meeting invite only  to those managed endpoints.
In General when OBTP is received and the user clicks the invite , it directs the endpoint to dial the meeting number created for the conference.
Sunr, thanks for the reply.  I'd like to follow up...
1) I do not want to create a booking from the AMX panel.  I just want to display a prompt for the next scheduled booking (with a JOIN button).  I was hoping to use the xFeedback Register /Event/Bookings but I have not been able to have that generate any messages.
2) In order to JOIN, it looks like I just do a DIAL command on the first number entry in the bookings list (*r Bookings Booking 2 DialInfo Calls Call 1 Number: "SomeNumber").  I am hoping that the bookings event (above) would provide me that same Number: "" to dial with the JOIN.
Thanks for the help,
Chad
Chad
The point is how are you scheduling the booking of the AMX panel from TMS. Probably i dont get what you refer by AMX panel. Is there a endpoint managed by TMS that uses AMX panel.
if so what is that endpoint ?
Sundar
Wayne DeNardi
You're best way would be getting your AMX to integrate with TMS through the Booking API rather than talking to the endpoint itself (for the first part of your first question).  You can then use the information retrieved by the API to present a button on your AMX at the right time which would dial the connection number presented by the API as your implementation of the second part.
This is how it is recommended to be done on Crestron equipment, so the AMX stuff should be the same - see https://communities.cisco.com/docs/DOC-47885
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
