Bug Cisco TelePresence Server MSE 8710
ginowrief
Dear All,
Have you encountered any bug with the the TPS Server 8710 Release 2.3 (1.55)?
Best Regards,
Fird
7 Replies 7
Patrick Pettit
HI Firdaush - Are you inquiring to something specific? Anything you want us to look at that you may be having a problem with? Let us know, and we can try and see whats up.
Thanks.
VR
Patrick
Hello Patrick,
Please find attach an image after the upgrade.
Fast Update requests received : 15448
Have you encountered this problem?
Tyler Wilkin
Firdaush,
There are usually a few caveats listed in the release notes of any given version:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/ts/release_note/Cisco_TelePresence_Server_Release_Note_2-3_1-57.pdf
For 2.3 it looks like there's an issue with quickly holding after a resume, as well as DTMF tone suppression.
luchand
There are a couple of issues from 2.3(1.55) which are fixed in 2.3(1.57), and there is also a 3.0 release now available which corrects some further issues - these are all documented in the release notes, but you can also get a complete list of known bugs from bug toolkit / the bug search tool.
Hello Luc,
This bug has not beel mentionned in the Release notes nor from Cisco Bug tool.
Patrick Pettit
HI Firdaush - I'll have to check some things and get back to you on that one.  Could in theory be network related as well for the fact that the TS received that many fast update requests and its constantly sending picture updates to the CTS.  Let me check around a bit more and get back to you.
VR
Patrick
Hello Patrick,
For information, PTP function correctly but not through TPS.
