02-17-2013 08:22 PM - edited 03-18-2019 12:36 AM
Hello, I have a C20 quickset which includes the above camera, this camera seems to have mechanical issues...when using pan and tilt to certain angles, it automatically jumps back to a 'home' position. There are no physical blockages around the camera and I've tried removing control/power cable and plugging back in several times. Has anyone else experienced this problem, or have any suggestions?
02-19-2013 04:56 PM
Hi Clinton,
What is the Software version you are running on the Endpoint ?
Could you pull the xstatus camera from the endpoint CLI mode.
Did you also tried to connect the same camera onto different codec ?
Please provide some more information so that we can proceed further.
Saurabh
02-19-2013 05:26 PM
Hi Clinton,
I would like to add on Saurabh information that in some software version below TC5.1.6, there were some camera issue, We are not sure which software version you have on C20, if it's not recent one, I would prefer to upgrade.
Vivek
02-19-2013 08:54 PM
Hi Saurabh, Vivek,
Thanks for the help, software is old: TC4.2...I want to upgrade it but apparently maintenance agreement is expired. Is there a way I can upgrade it?
This installation only has 1 codec and camera unfortunately, so no test-swapping between endpoints.
xstatus camera 1
*s Camera 1 Connected: True
*s Camera 1 HardwareID: "50000003"
*s Camera 1 Manufacturer: "TANDBERG"
*s Camera 1 Model: "PrecisionHD 1080p 12X"
*s Camera 1 SoftwareID: "S01718-4.0FINAL [ID:40083] 2012-12-10"
*s Camera 1 SerialNumber: "A1AB40D00211"
*s Camera 1 IpAddress: ""
*s Camera 1 MacAddress: ""
*s Camera 1 Position Pan: 288
*s Camera 1 Position Tilt: 30
*s Camera 1 Position Zoom: 2879
*s Camera 1 Position Focus: 4287
*s Camera 1 Capabilities Options: "ptzf"
** end
OK
Any further thoughts on this?
Clinton
