Telepresence server endpoint resolution
Justin Pascal
I want to join an endpoint or video stream which will act as a participant but will display a logo what's the _mininum_ resolution and frames per second I can send to Tps 2.3? thanks
Saurabh Gupta
Level 3
Level 3
Hi Justim,
I believe the minimum resolution would be CIF resolution supported by the endpoint and minimum frames would be 5fps.
Saurabh
