C20 Web Access Password
hunkw
hi, All,
Somebody forgot the password of C20 Web Access .
So there seems only two ways to handle this.
1) When powered down, pressing the power switch for fifteen seconds (until the green LED in the front of the system turns red. And confirm the reset by two short presses within the next five seconds.
2)Login through RS232 seriaport, and input the command: "xcommand systemunit factoryreset"
But here comes a promblem,
Method 1) can't work with C20 (Soft version: TX5.1.1).
And  we can't get in with RS232. (38400, 8, none.1)
How could it be? Shall we have another way ?
Thanks!
Dharmesh Nandoria
HI,
Power down the C20. This can be done by:
  • If the C20 is currently running, press the physical reset button and release. The C20 will power down.
  • If the C20 is in some type of boot loop, pull the power adapter (next to the reset button)
Once the C20 is powered down, press and hold the reset button. If you  unplugged it to power it down, hold down the reset button and plug in  power adapter.
After approximately 10 seconds the status LED will start blinking  slowly. Release the button and push it twice within the next 5 seconds.  The LED will start blinking faster indicating it is booting.
After a successful factory reset, a confirmation message will be written on the screen after the boot is complete.
Kind regards,
Dharmmesh
Danny De Ridder
from our documentation I read that the reset method via power button on C20 starting from release TC5.1 is as follows :
Physical Factory Reset C20 TC 5.1 and later
Turn the C20 off by pressing the physical reset button. Now hold the  physical reset button for 10 seconds, the LED will start blinking.  Release the button and push it twice within the next 5 seconds. The LED  will go solid and the factory reset will begin. After a successful  factory reset, a confirmation message will be written on the screen on  the next start.
For the serial access you need to have a special Y-cable with the settings 38400, 8, N, 1. Do you have such a cable?
Please try the power button procedure above. It differs from what you describe.
Dharmesh Nandoria
HI,
Kind regards,
Dharmmesh
hi, Dharmmesh,
Thank you all very much.
Plug out and in, and holding the resetbutton is the correct fuction.
It did work.
I feel it best to be in OSD like MXP serias.
Anyway, Thanks!
hunk
