C20 with external camera
hey, can i user cisco C20 with an external camera ? (sony or any camera used by cameraman)
thanks.
tkiel
If the external camera uses hdmi it should not be an issue.
Thomas
cgiovann01
Standards based camera with HDMI will work. We have a mix of Sony and Tandberg camera on C series deployments. No issues
Hi.
Any camera using visca protocol should work with codec , You need to make your own cable for connection to codec as it will have diffrent type of connector at camera end.
Sony HD1 and Sony HD7- This cameras are tested with C series codec.
Kind regards,
Dharmmesh
thanks a lot for your help,i will try and let you know.
