05-05-2015 08:35 AM - edited 03-18-2019 04:26 AM
What is the maximum cable length for the camera control port on a Cisco C40?
Kyle
Solved! Go to Solution.
05-05-2015 06:34 PM
According to the PrecisionHD Camera Guide, on pg 17, the camera cables that typically come with the codecs can be 5, 6.5, or up to 20 meters. Anything over 5 meters requires the camera be powered by the camera's power supply and not from the codec using camera control cable itself.
I have some custom installs where the camera control cable is well up to 75-100 feet. Simply follow the pin-out on the same page noted above to make your own cable, and be sure to use the PSU-CAM-V= power supply to power the camera.
05-05-2015 06:34 PM
05-06-2015 06:57 AM
Hi Patrick,
Thank you so much for passing along this information. I had overlooked that information on page 17 where it points out the CAB-VDCD-20M cable.
I appreciate you taking the time to help me out!
Kind regards.
