Cable Microphone Mic60
I have a mic60 mic but the cable was damaged. I have no guarantee. What cable can I use from another manufacturer to replace it since I have the connector euroblock but not the cable
Elias Sevilla Duarte
All I know is that the cable needs to be female in one end and male in the other end, and 3 pin terminal block to 3 pin terminal block.
If you do not have warranty, the cable can be ordered. Here is the PID CAB-MIC-T60.
Hope that helps.
