11-21-2017 08:26 AM - edited 03-18-2019 01:38 PM
Dear Colleagues,
We have a fully functioning UC infrastructure with Expressway-Core/Edge and CMS and I would like to enable incoming SfB calls to CMS room.
What do we have:
- Public certificate on Edge
- Turn server on Edge
- Traversal zone between Core and Edge
TLS enabled
Do not check credentials
- Neighbor zone between Core and CMS
TLS enabled
- Search rule on Edge
Protocol: SIP (All variants)
Source: Default
Regex pattern: room@domain.com.*
Target: Traversal zone
- Search rule on Core
Source: Traversal zone
Target: CMS
- Incoming call handling on CMS
Domain: domain.com
Target spaces: yes
- Space on CMS
URI part: room
- TURN settings on CMS
TURN server address: Edge internal
Proper username/psw
During the test I experienced that I was able to call the CMS room from Cisco devices and Spark only, but not from SfB.
From the TCP dump of Edge external interface I saw that during SfB attempts, there are TCP packets only, no UDP at all.
Is there anything I missed?
Laszlo
Solved! Go to Solution.
11-24-2017 12:34 AM
Do you see a search request on your Expressway-E coming from SFB?
Have you checked firewall?
And can I confirm this is for external SfB participants from other organizations?
I rolled something like this out recently and I didn't need to set anything special up, other than the _sipfederationtls SRV records pointing to Expressway-E.
Expressway-E directed inbound calls to CMS regardless of the SIP variant, so long as the right URI was dialled.
I know that SfB *can* be a bit funny about DNS records and SIP domains, in my case the Exp-E's hostname was vc.domain.com, which was also our SIP domain.
11-24-2017 12:34 AM
11-27-2017 12:27 AM
Hi Nick,
You were right, as it turned out, the SfB client was in a restricted network.
The security engineer told me that there is no restrcition regarding the outbound connection, but the logs don't lie :-)
Thanks, Laszlo
