Calls drop on a Jabber (Video) client after 30 seconds when dialling into a TelePresence Server
david.reid66
Hi Guys,
Calls drop on a Jabber (Video) client after 30 seconds when dialling into a TelePresence Server. This happens if the client is connected to the customer wireless. If the Jabber client is connected through the customer LAN or from home (only had one user to test) the call was fine. Points to point calls are also fine.
It was initially thought that this was due to a VCSc/e upgrade from X7.2.3 to X8.6.1 but after rolling the VCS’s back to X7.2.3 the wireless calls were still not working but the customer is sure that it has been working.
Either way,it’s not working now and I can see in the TPS event log that there’s an “INVITE” timeout:
40176 2015/11/06 22:40:47.203 SIP                Error     call 4775: Ending call due to INVITE transaction timeout
 40195 2015/11/06 22:40:47.204 SIP                Error     call 4775: BYE transaction failed due to network error
The Windows Jabber SIP log from C:\~\ AppData\Local\Cisco\JabberVideo\Logs, has the following snippet, which shows a “SIP_INVITE_REJ”:
2015-11-06 22:58:17,526 WARNING PID 7260 TID 14300 SIP
Failed to find flow for outbound proxy: 91.212.138.52:5060, using default registration, 0
2015-11-06 22:58:17,526 DEBUG PID 7260 TID 14300 SIP
fsm-S: SipTrnsp-0 -> SipReg-0  SipTrnsp_Connection_Lost_Ind
2015-11-06 22:58:17,527 DEBUG PID 7260 TID 14300 SIP
fsm-S: SipTrnsp-0 -> SipTrLay-0  SipTrnsp_Msg_Excpt
fsm-R: SipReg-0 (Active) <- SipTrnsp-0 [I] SipTrnsp_Connection_Lost_Ind
SipTransport indicates that connection to  was lost.
fsm-R: SipTrnsp-0 (Ready) <- SipTrans-27 [I] SipTrnsp_Trans_Term_Req
fsm-R: SipTrnsp-0 (Ready) <- SipTrans-28 [I] SipTrnsp_Trans_Term_Req
2015-11-06 22:58:17,527 INFO PID 7260 TID 14300 SIP
SipDialog(ui=3,s=0) InviteSent_doSIPTransRej: received iTUCookie = b
SipDialog(ui=3,s=0) sendInviteRejToStack (0:Connection closed by remote side)
fsm-R: SipEvNotify-0 (Active) <- SipUa-0 [I] SIPTrans_Rej
rejected transmission:transid 53
Got 481 on Subscribe, ment for uk-bridge-12@laingorourke.com, expires: 0
SipUa GRUU added OK
fsm-R: G2FSM-0 (Ready) <- SipStack-0 [I] SIP_Invite_Rej
_status_code_to_ended_reason: reason=5
_taf_sip_call_agent_invite_rej: reason: 0: 0: Connection closed by remote side
I’ve read other threads and most suggest that it’s a “network/firewall/ALG” issue but what precisely is the problem? Telling the customer it’s a “firewall” issue isn’t very helpful unless you tell them what to look for. I’ve asked them to check the firewall  for any packet drops but they don’t see anything.
I can add logs if they'll help.
The current versions are:
VCSc/e – X7.2.3
TPS - 4.0(2.8)
Conductor – X2.3
David
James Hodgson
Hi David,
It's difficult to tell exactly what is wrong here without the TelePresence Server logs directly, but in general a TS will attempt to re-INVITE back to a client calling in withing a few seconds of the start of the call (basically after the lobby screen) and if it gets no response to this message it will hang up the call after 30 seconds (the same thing will happen after ~15 minutes depending on your session refresh interval.) The exact destination IP address for this message will depend on what was included in the original SIP INVITE message from the Jabber client and will have been modified by each of the intermediate SIP proxies.
I'm assuming that depending on whether or not the client is connected wired ro wirelessly affects what IP address it is assigned and thus affects only the routing of the final hop (between the UCM and the Jabber client.) If a firewall is a fault here you will need to look into anything blocking that link. Alternatively if the different IP address causes it to register to a different device, this could affect further call routing and prevent the upstream re-INVITE. I'd certianly recommend you look at the differences in the signalling between the two cases to see if the wireless case is travelling to a completely different destination.
James
Hi James,
Thanks for your assistance.
I’ll speak with the customer about the points you raise.
In a trace I took last week on the TPS, I’ve removed/replaced the customer domain name with <domain> to hide it. I’ve done the same with the SIP log from my laptop that was used for some Jabber video client calls.
They have a pair of TPS’s on 10.80.120.2 & 10.80.120.3
They have a pair of Conductors on 10.80.120.10 & 10.99.120.10
Client 192.168.0.4 (and maybe 192.168.0.13)
{Note: there's no CUCM in this}
Looking for INVITE message in the TPS log I see the following only referencing the client address 192.168.0.4:
39723 2015/11/06 22:40:09.400 SIP               Detailed top line label = "INVITE" value = sip:88811482@10.80.120.2 SIP/2.0
39729 2015/11/06 22:40:09.401 SIP               Detailed Found "To" = "<sip:88811482@10.80.120.2>" 39730 2015/11/06 22:40:09.401 SIP               Trace     Extracting URI from "<sip:88811482@10.80.120.2>"
39731 2015/11/06 22:40:09.401 SIP              Detailed Found "From" = ""Steve Carlisle" <sip:scarlisle@<domain>>;tag=fb0b29d54f9d8f8e"
39732 2015/11/06 22:40:09.401 SIP               Trace     Extracting URI from ""Steve Carlisle" <sip:scarlisle@<domain>>;tag=fb0b29d54f9d8f8e"
39733 2015/11/06 22:40:09.401 SIP               Detailed Found remote tag fb0b29d54f9d8f8e
39734 2015/11/06 22:40:09.401 SIP               Detailed Found "Call-ID" = c21d05b3189203a1@192.168.0.4
39738 2015/11/06 22:40:09.401 SIP               Info     Incoming call from 10.99.120.10:39525
39739 2015/11/06 22:40:09.401 SIP               Trace     Connection c2130003 received Request PDU INVITE
39740 2015/11/06 22:40:09.401 SIP               Trace     Extracting URI from "<sip:88811482@10.80.120.2>"
39748 2015/11/06 22:40:09.402 SIP               Trace     Handling INVITE request
39749 2015/11/06 22:40:09.402 SIP               Trace     Extracting URI from "<sip:10.99.120.10:5073;transport=tls>"
39750 2015/11/06 22:40:09.402 SIP               Trace     Extracting URI from ""Steve Carlisle" <sip:scarlisle@<domain>>;tag=fb0b29d54f9d8f8e"
39751 2015/11/06 22:40:09.402 SIP               Trace     Received remote tag
39752 2015/11/06 22:40:09.402 SIP               Trace     Extracting URI from "<sip:88811482@10.80.120.2>"
39753 2015/11/06 22:40:09.402 SIP               Trace     Extracting URI from "<sip:88811482@10.80.120.2>"
39754 2015/11/06 22:40:09.402 SIP               Trace     Extracting URI from ""Steve Carlisle" <sip:scarlisle@<domain>>"
39755 2015/11/06 22:40:09.402 SIP               Trace     Received remote tag
39756 2015/11/06 22:40:09.402 SIP               Trace     Sending response 100 Trying no content
39757 2015/11/06 22:40:09.402 SIP               Trace     Extracting URI from "<sip:88811482@10.80.120.2>"
39758 2015/11/06 22:40:09.402 SIP               Trace     Sent 100 Trying to 10.99.120.10:5073
39759 2015/11/06 22:40:09.402 SIP                Trace     Handling Incoming Call
39760 2015/11/06 22:40:09.402 SIP               Detailed Searching for handle for TLS connection to 10.99.120.10:5073
39761 2015/11/06 22:40:09.402 SIP               Trace     Found exisiting TCP handle for 10.99.120.10:5073
39762 2015/11/06 22:40:09.402 SIP               Detailed incTCPRxUsage; handle: 0x657 count: 3
39763 2015/11/06 22:40:09.403 SIP               Trace     Route 1 for c2130003 linked to 00000657
39764 2015/11/06 22:40:09.403 SIP               Trace     Analysing SDP
39765 2015/11/06 22:40:09.403 SIP               Trace     New connection accepted
39921 2015/11/06 22:40:09.465 APP               Info     call 4775: "Steve Carlisle" now joined conference "UK-Bridge-12@<domain>"
39929 2015/11/06 22:40:09.465 SIP               Trace     Queueing up new INVITE transaction
39933 2015/11/06 22:40:09.466 SIP               Trace     Starting INVITE transaction
39951 2015/11/06 22:40:09.469 SIP               Trace     Sent INVITE to 10.99.120.10:5073
39966 2015/11/06 22:40:09.501 SIP               Detailed Found "From" = ""UK-Bridge-12@<domain>" <sip:88811482@10.80.120.2>;tag=0048AEAEC2130003"
39967 2015/11/06 22:40:09.501 SIP               Trace     Extracting URI from ""UK-Bridge-12@<domain>" <sip:88811482@10.80.120.2>;tag=0048AEAEC2130003"
39968 2015/11/06 22:40:09.501 SIP               Detailed Found local tag 0048AEAEC2130003, 16
39969 2015/11/06 22:40:09.501 SIP               Detailed Found "To" = "<sip:scarlisle@<domain>>;tag=fb0b29d54f9d8f8e"
39970 2015/11/06 22:40:09.501 SIP               Trace     Extracting URI from "<sip:scarlisle@<domain>>;tag=fb0b29d54f9d8f8e"
39971 2015/11/06 22:40:09.501 SIP               Detailed Found remote tag fb0b29d54f9d8f8e
39972 2015/11/06 22:40:09.501 SIP               Detailed Found "Call-ID" = c21d05b3189203a1@192.168.0.4
39978 2015/11/06 22:40:09.501 SIP               Trace     Call-ID OK
40080 2015/11/06 22:40:15.196 SIP                Trace     Queueing up new INVITE transaction
40084 2015/11/06 22:40:15.196 SIP               Trace     Starting INVITE transaction
40093 2015/11/06 22:40:15.197 SIP               Trace     Sent INVITE to 10.99.120.10:5073
40173 2015/11/06 22:40:47.203 SIP               Trace     Unable to complete failover due to lack of alternative servers, clearing route
40174 2015/11/06 22:40:47.203 SIP               Detailed decTCPRxUsage; handle: 0x657 count: 2
40175 2015/11/06 22:40:47.203 SIP               Trace     Route 1 for c2130003 unlinked from 00000657 40176 2015/11/06 22:40:47.203 SIP               Error     call 4775: Ending call due to INVITE transaction timeout
40177 2015/11/06 22:40:47.203 SIP               Trace     Freed client transaction. 1604 free
40178 2015/11/06 22:40:47.203 SIP               Trace     Enter SIP Connection closed
4079 2015/11/06 22:40:47.203 SIP               Trace     SIP Connection closed
40180 2015/11/06 22:40:47.203 CMGR               Info     call 4775: disconnecting, "scarlisle@<domain>" - timeout
40181 2015/11/06 22:40:47.203 APP              Info     call 4775: tearing down call from "Steve Carlisle" - destroy at far end request; timeout
40182 2015/11/06 22:40:47.203 SIP               Trace     Queueing up new BYE transaction
In the attached desktop client SIP file I see the IP address 192.168.0.4 in all of the application/sdp messages:
Content-Type: application/sdp
Content-Length: 2184
v=0
o=tandberg 1 4 IN IP4 192.168.0.4
s=-
c=IN IP4 192.168.0.4
However, I also see the address 192.168.0.13 being received from an external address (hidden 2nd & 3rd octets) 193.x.x.102 which I assume is their wireless?
Via: SIP/2.0/TLS 192.168.0.13:19527;branch=z9hG4bKbf17a742911864b99929963c05d49f63.1;received=193.x.x.102;rport=19527;ingress-zone=DefaultSubZone
Is the 192.168.0.13 a red herring, or is this part of the issue?
Thanks again,
David
Can the jabber users ring eachother over the WLAN?
It looks like SIP ALG is enabled on the WLAN maybe.
It look like your Jabber Video is registering to the VCS E at its public IP address and in my understanding, you´want to reach the TLPS internally.
Check at the VCSs for this endpoint URI registration and confirm if it is registered at the VCSE or the VCS C.
REGISTER sip:<domain> SIP/2.0
Via: SIP/2.0/TCP 192.168.0.4:29095;branch=z9hG4bKa6d66bcb02505778342c6f49c7d4524a.1;rport
Call-ID: e790551ae192d481@192.168.0.4
CSeq: 21282 REGISTER
Contact: <sip:scarlisle.jabber@192.168.0.4:29095;transport=tcp>;+sip.instance="<urn:uuid:457eac8c-5f2a-501b-84b6-91fd5b651ebb>"
From: <sip:scarlisle.jabber@<domain>>;tag=86a6c76ad55cfa0f
To: <sip:scarlisle.jabber@<domain>>
Max-Forwards: 70
Route: <sip:91.212.138.52:5060;lr>
If you need to register at the VCSC, you can try to remove the external address from the Jabber Video (leave empty) and configure the Internal Server field only, pointing to the VCS C IP Address.  In this way you will overrride any DNS misconfiguration and can confirm that it is registered at the VCS C and try again.
When in a call, check at VCS Call status for the path if it is what you expect and check the IPs.
PS: If the call is going to outside using the wi-fi, the Internet Firewall may have some SIP configuration do inspect SIP call. Try to use TLS intead TCP to check if it works, but if thi wi-fi have connectivity with the corporate network where VC infra resides, the Jabber Video should register at the VCS C.
