Camera ttc8-05 standalone with trc6
salem
We want to use the camera ttc8-05 standalone with the trc6 remote. Moving up, down, left and right is done, but zooming is not done.
regards,
Wayne DeNardi
When the camera is not connected to a codec, the TRC6 doesn't support the zoom (as the +/- buttons are used for two purposes, both for zoom and as volume buttons depending on what state the codec is in).
You'll need to use one of the older TRC5 remotes which has separate zoom and volume buttons.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Thanks Wayne,
Is there any solution for trc6?
No.  As per my previous response, the TRC6 will not work for this purpose.   You will need a TRC5.  You should be able to pick one up second hand relatively cheaply.
Wayne
