connection lost in cisco meeting server
hamed1986
Hello guys,
i implement single cisco meeting server and published cms from ASAv to the internet. when I connect to each space, after couple of time I disconnected and rejoin automaticlly.
this is error :
cms> syslog follow
2024-06-13T01:02:24.427 user.info cms host:server: INFO : call 275: inactivity notification for "Hamed"; tearing down...
2024-06-13T01:02:24.427 user.info cms host:server: INFO : call 275: destroying API call leg 5968822f-ba69-4763-a783-baa049424149
2024-06-13T01:02:24.427 user.info cms host:server: INFO : call 275: "guest2073807939" / "Hamed" resource; deactivating due to call drop
2024-06-13T01:02:25.231 user.info cms host:server: INFO : user "guest2073807939", conference "Damavand.Conf" association deactivated due to inactivity call drop
2024-06-13T01:02:25.231 user.info cms host:server: INFO : conference 58f41ca9-9970-40dc-a7b0-e7e6f7349149 destroyed
2024-06-13T01:02:25.231 local0.info cms host:server: INFO : participant "guest2073807939" left space c3ce3aa1-000f-4795-842e-ac26b4304836 (Damavand.Conf)
2024-06-13T01:02:25.231 user.info cms host:server: INFO : removing guest account 'guest2073807939' (name 'Hamed') on call drop
2024-06-13T01:02:25.232 user.info cms host:server: INFO : destroying guest account with user ID "guest2073807939"
2024-06-13T01:02:25.232 user.warning cms host:server: WARNING : sending session end message to participant 5968822f-ba69-4763-a783-baa049424149 due to error condition (reason=12)
2024-06-13T01:02:25.309 local0.info cms cli: User admin from 192.168.255.14:51351 issued command < syslog follow>: permission granted
2024-06-13T01:02:26.767 user.warning cms host:server: idle server management conferences: num created / destroyed = 131 / 129 leaving 2 (previously 3)
2024-06-13T01:02:28.960 local0.info cms client_backend: INFO : WebApp Audit : Session: 9f6329ee-f8a6-414a-9794-5fc881a20a91 : Participant Hamed performed action of join call
b.winter
Could you describe your infrastructure setup?
Where is the CMS placed? Where is the FW? Do you NAT from a public IP to CMS private IP? etc ...
Just by your short description, the problem could be anything.
The Cisco setup for CMS with public access is like this:
1 CMS (Core) in the internal network and 1 CMS (Edge) in the DMZ, providing TURN relay (behind the NAT-FW).
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Deployment_Guide/Version-3-9/Cisco-Meeting-Server-3-9-Single-Split-Server-Deployment.pdf
before I explain my design I want to say thank you for your respond. I designed single CMS and set IP private to all it's component and after that connected CMS to ASAv for publishing and I open https and http on ASAv.that's all my design.
@b.winter by the way i deploy webbridge3 callbridge dns ntp that's all component deployed on cms
I guess you have a problem with the media connection over the NAT. Because you have no TURN-server in your deployment, which provides this media relay via NAT.
That's why you have Expressway or CMS-Edge as TURN-server in the DMZ.
