can CUBE register with two CUCM clusters?
learner2008
We have two CUCM clusters - one is in US and one is in Australia. Currently CUBE is registered with US Cluster with the settings below -
sccp local GigabitEthernet0/0
sccp ccm 10.10.1.21 identifier 2 priority 2 version 7.0
sccp ccm 10.10.1.20 identifier 1 priority 1 version 7.0
sccp
Now we need CUBE to communicate with Australia CUCM. Should we set sccp up for Australia CUCM cluster (version 6.0)?
Jessica Wang
carunach
I think you are refering to registering media termination points / transcoders on the same router to two different CUCM clusters, correct?
If yes, we can do it by creating separate sccp ccm groups.
Example :
sccp ccm identifier 1 version 7.0
sccp ccm identifier 2 version 7.0
sccp ccm identifier 3 version 7.0
sccp ccm identifier 4 version 7.0
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register Transcoder1
sccp ccm group 2
associate ccm 3 priority 1
associate ccm 4 priority 2
associate profile 2 register Transcoder2
dspfarm profile 1 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 5
associate application SCCP
dspfarm profile 2 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 5
Arun
Yes, that is what I am looking for.
Another quick question, is the MTP required on CUCM in order for CUCM to interwork with CUBE?
Thanks.
It depends on the call flow and software versions. For most call flow scenarios and latest software versions, MTP is not required. Please refer the following documents in regard :
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
http://www.cisco.com/en/US/customer/docs/ios/voice/cube/configuration/guide/vb-gw-sipsip_ps5640_TSD_Products_Configuration_Guide_Chapter.html#wp1443323
Arun
