07-19-2017 07:48 AM - edited 03-18-2019 01:19 PM
I need to configure TMS booking for meeting using my
07-19-2017 10:58 AM
You need TMSXE (Exchange Integration) setup with TMS, and with that you can use Webex Productivity tools to schedule meetings that push the Webex connection info to the endpoints while providing the Webex info to the meeting invitation. See this document for details.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmsxe/install_guide/Cisco-TMSXE-Deployment-Guide-5-3.pdf
07-19-2017 11:08 AM
OBTP for CMR Cloud is supported with TMSXE 5.2 and later, refer to the TMSXE Deployment Guides on how to set it up.
One thing to note, the guides are a bit misleading, OBTP for CMR Cloud is mixed in with the WebEx Scheduling Mailbox section of the guide, making you believe you need to have CMR Hybrid, this is not the case. All you need to do is deploy TMSXE as normal with room mailboxes for your TMS managed endpoints. To schedule a OBTP conference with CMR Cloud, simply create a WebEx invite within Outlook and invite the TelePresence rooms to the meeting, TMSXE will parse the video address from the WebEx invite and schedule the conference within TMS.
