Cisco Meeting Server Congfiguration Help Required
Muhammad Talha
I have install core,edge and database and need to configure it can any one help me in this regard
32 Replies 32
Patrick Sparkman
CMS database is part of the Core server, refer to the CMS Configuration Guides on how to configure the database.
Hi All,
Can you please confirm which license is used by Call bridge
Product Description
LIC-S52010-CE-K9 License Key Software Encrypted
LIC-SMP+EP Shared Multiparty License for 1 Concurrent Meeting
CON-ECMU-LICSMPEP SWSS UPGRADES Shared Multiparty Li
LIC-TP-ROOM-11.X Choose if VCS or for CUCM version 11.x TP-Room License
LIC-EXP-RMS-PMP RMS Licensing included with PMP & SMP
LIC-EXPE-PMP-PAK Expressway Series, Expressway-E PAK
LIC-TP-SMP-INC Shared Multiparty License for 1 Concurrent Meeting
LIC-CMS-PAK Cisco Meeting Server (CMS) PAK
LIC-CMS-SMP Shared Multiparty License for 1 Concurrent Meeting for CMS
LIC-VMCNDTR-PMP-PK PAK for virtual Conductor
Product Description
CUWL-PMP+K9 Migration from CUWL Pro, PMP or Acano to PMP Plus
CON-ECMU-CUWLPMP9 SWSS UPGRADES Migration from CUWL
LIC-2-PMP+ Cisco Meeting Server (CMS) PMP License for 1 Concurrent Meet
CON-ECMU-LIC2PMP SWSS UPGRADES Cisco Meeting Server
LIC-EXP-MSFT-PMP Microsoft Interoperability Option
LIC-TMS-PMP-PAK TMS PAK for Configuration Use
LIC-CNDR-PMP-C2400 Conductor 2400 call sessions license
LIC-CNDTR-PMP-CL Conductor clustering support
LIC-TMS-25-PMP Cisco TMS - Additional 25 Direct Managed Systems
LIC-TP-PMP-USER 1 XC PMP User License
LIC-CMS-PMP-M-USER Cisco Meeting Server (CMS) PMP License for 1 Concurrent Meet
CON-ECMU-LICMUSER SWSS UPGRADES Cisco Meeting Server
LIC-CNDTR-PMP-B30 Conductor license, support up to 30 bridges
LIC-CNDTR-PMP-K9 Conductor License for Base Encrypted Software Image
It comes with SMP or PMP licenses. SMP (Shared multiparty) shared across pool of user for conference and PMP is kind of named licenses apply to named user. So if the user initiate an adhoc conference who is allocated to PMP pool will consume PMP licenses, however if the user is not part of PMP allocation pool then it uses SMP license.
LIC-CMS-PMP-M-USER
This are all CMS licenses.
Alok
Hi Alok,
I have observed below error can you please guide also i have used selfsigned certificate for webadmin and call bridge is it ok??
have you installed license  on the server ? you can winscp into the system and then upload the license file there.
if you run the command "license" on the CLI it gives the details about the installed license, otherwise output of the command will not return any result.
Alok
How to check CMS server Mac Adress??
you can run the command on CLi "iface a" and this will give you the mac-address.
I hope you are allocating your components to interface "a" on the core.
Alok
Hi Alll,
I have done below configuration on my core is it correct?Using self signed certificate
pki selfsigned webadmin
webadmin certs webadmin.key webadmin.crt
webadmin listen a 443
webadmin restart
webadmin enable
webadmin disable
webadmin listen a 445
webadmin enable
pki selfsigned callbridge
callbridge certs callbridge.key callbridge.crt
callbridge listen a
callbridge restart
That's the very basic of it, There is more config involved when you go further. like using postman api for LDAP config, user profile creation etc. Also look at the config guide for webrtc using cms with expressway.
Also you need to define rules for incoming and outgoing calls.
Alok,
Hi Alok,
Can you please share any customized guide for LDAP config and user profile creation??
Here are the guides: CMS Configuration Guides and CMS API Guides.
Hi All,
Need help in below query
Title:
CMS SRV record
Description:
Callbridge generate the following domain but our DNS team has concern that's it a public domain instead of this you can you internal domain i.e. nfoods.complease guide
Callbridge : cms
Domain : uc.xcloud-hk.com
Secret : 7L2pbQpu6ABaN8DhAb1
Hi Guys,
Thank you for your kind support. I am able to Dial successfully from Cisco Meeting App.No the task is we have to configure Webbridge for WebRTC client and test the call through WebRTC client.Can any one help me in this regards??
you need to refer the guides mention above.
regards,
Prasad Paradkar
