04-12-2013 12:58 AM - edited 03-18-2019 12:55 AM
Can i use the SX20 Touchpad on an Edge 95?
Solved! Go to Solution.
04-12-2013 01:02 AM
Hi Markus,
It will not work . SX/ C series are having diffrent hardware and software .
Kind regards,
Dharmmesh
04-12-2013 01:02 AM
Hi Markus,
Kind regards,
Dharmmesh
04-12-2013 01:12 AM
Hi Dharmmesh,
thanks for your help. I´m sorry for inaccurate information, are we talking about the CTS-CTRL-DVC8?
Kind regards,
Markus Schimanski
04-12-2013 09:21 AM
Hi Markus,
Agreed with Dharmesh, C/SX/EX Series touch panel will not work with the MXP Series.
Yes, we are talking about CTS-CTRL-DVC8 here.
It is designed to work with C/SX/EX series only.
You Can either use MXP remote control or Crestron or AMX Touch Panel with MXP which works through the serial port of the Codec.
Saurabh
06-17-2014 11:12 PM
Which Solution from Creston or AMX would be best suited to do the same job as the In-Touch8?
Any Information would be helpful as the offered devices many unnecessary features for our rooms
06-19-2014 02:26 AM
I would say it is less the brand, its how the control panels are programmed and where you can get better support.
An other option could be to look into new systems like a SX20 with a Cisco touchpanel.
