Can't control precision HD camera 4x
sheryl.brown
Does anyone know how to control Precision HD 4x Camera through the actual codec using the Crestron (C40 C60 C90) codec control module? The only way we have been able to control the camera is through a direct connection to the camera.
Tomonori Taniguchi
PHD camera may control from Codec by using “xcom camera” API.
xCommand Camera PositionSet
   CameraId(r): <1..n>
   Pan: <-65535..65535>
   Tilt: <-65535..65535>
   Zoom: <0..65535>
   Focus: <0..65535>
xCommand Camera Ramp
   CameraId(r): <1..n>
   Pan:
   PanSpeed: <1..15>
   Tilt:
   TiltSpeed: <1..15>
   Zoom:
   ZoomSpeed: <1..15>
   Focus:
xCommand Camera TriggerAutofocus
   CameraId(r): <1..n>
* “n” is depend on Codec type.
You may use preset API as well
If looking for camera control from Crestron system via Codec, you should send these API to codec from Crestron control application.
