Can't Install Cisco VCS-C&E
Hello All,
I tried to install the VCS-C&E into my VM ESXI with the free version one(OVA). But I don't why I can't install it. Is that issue from Cisco VCS OVA or from VM ESXI?
Please help to assist !
@Syed
Level 3
Level 3
What is the ESXI version?
My EXSI V 6.5
Make sure your OVA file downloaded correctly (ie check that the MD5 or SHA512 checksums are valid).
Also make sure you are using the correct OVA for 6.5 and not the one for 6.0 and earlier.
https://software.cisco.com/download/type.html?mdfid=283733603&flowid=77856
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Mohammed Khan
OVA Should be deployed after login to ESXI, Refer below link page 17
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/install_guide/Cisco-Expressway-Virtual-Machine-Install-Guide-X8-9.pdf
Do you have a the Expressway OVA file? Do you see any error while you deploy ova?
