Can't upgrade software on C40 - From TC6.1.1 to TC7.3.7
nick.diaz1
Has anyone experienced the same issues I am experienced? If so, I'm curious as to how you solved it. I need some help.
I'm trying to update the software on my C40, going from TC6.1.1 to TC7.3.7. Everytime I try this the codec gets stuck in:
Initializing installation, please wait...
Running post-install hooks from installed package
The only way I can fix this is by power cycling it, and SSHing into it and doing a factory reset. But that doesn't fix the problem because the codec stays in TC6.1.1. I have even tried to go 6.3.1 or 6.3.2 but it doesn't work and I get the same result. I can't even get logs or anything because the codec stays in Maintenance Mode even after a power cycle. I have left the codec sitting doing its thing for days but nothing happens. Any ideas on how to fix this would be greatly appreciated.
Wayne DeNardi
If the endpoint keeps going in to Maintenance mode no matter what version you install, then it is likely that the unit has some faulty flash or other hardware.  I would suggest you log a call with the TAC and organise an RMA.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
