Can the Sx20 connect to Webex Connect and Callmanager without a VCS?
benbollinger
Level 2
Level 2
We have a few standalone sx20's that use webex connect, but would like them to be able to communication with callmanager video endpoints as well.  Is there any way to accomplish this?
CCM 8.6
Ben, you're correct, selecting a native CUCM registration will disconnect you from the WebEx TelePresence (Callway) service.  There is no easy way to accomplish what you are looking for without a VCS.  You are connected to a cloud service, that performs Call Control comopletely detached from the internal network with CUCM.  VCS Control and Expressway would enable this through a standard deployment.
I wouldn't recommend this, but the only way to accomplish this would be to manually change the endpoint over to a CUCM registration and then back to WebEx TelePresence each time.  WebEx TP will allow you to re-register the same endpoint with the same MAC multiple times. The problem is that this workaround does not scale.
5 Replies 5
Marius Nedregaard
That is possible.
You can register the SX20s directly to 8.6 call manager.
Check this link for a quick start guide named: "Administering TC endpoints on CUCM 8.6"
http://www.cisco.com/en/US/docs/telepresence/endpoint/codec-c-series/tc5/administration_guide/cts_endpoint_administration_ucm86_quick_start_guide_tc50.pdf
//Marius
When I select CUCM instead of Callway it won't be connected to webex connect though, correct?  I'd like it to connect to both at the same time.
Thanks George.  That's what I thought as well, but just wanted to make sure there wasn't any other way.
Revised April 30, 2013
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tms/config_guide/webex_enabled_telepresence/cts_webex_call.html
Introduction
This chapter describes how to configure call control for Cisco WebEx Enabled TelePresence meetings.
To begin using Cisco WebEx Enabled TelePresence, you must configure the call control product(s) used in your video network.
There are three possible call control scenarios:
•Cisco TelePresence VCS Control and Expressway
Endpoints are registered to VCS Control and/or Expressway only.
•Cisco Unified CM with VCS Control and Expressway
Endpoints are registered to Unified CM only.
•Cisco TelePresence VCS Control and Expressway with Unified CM
Endpoints are registered to VCS Control/Expressway and Unified CM.
