Can u proxy between two LOCAL zones on a Gatekeeper?
majszakm
Is it possible to proxy a call between two local zones on the same gatekeeper?
Thanks for any replies.
gsykes
I also tried this last year to overcome issues with Access Control Lists preventing school sites from directly communicating with each other, and unfortunately the answer is no! The proxy will only work with calls to remote zones.
However from version 12.3 (4)T of the MCM gatekeeper IOS, there is also a feature included called IP to IP gateway, which will do what you want, and will actually work better than the proxy as it is codec transparent (the proxy will re-encode your VC to H.261 and G.711).
More info can be found here:
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_qanda_item09186a00801da69b.shtml
vraut
http://cisco.com/en/US/products/sw/voicesw/ps5640/index.html
Try this product, you may need the latest IOS though.
The IP-IP gateway can do what you have requested, for Voice and Video H.323 calls with RSVP CAC.
