06-09-2016 10:48 PM - edited 03-18-2019 12:45 PM
I just want to add layouts in SX20 manually...Is this possible???
06-13-2016 12:53 AM
Thanks Patrick.....
06-13-2016 02:47 AM
Greetings of the day!
You can add and customise layouts through TC console software.
However, the SX20 codec does not support it. It is only supported for SX80, C40, C60 and C90 codecs.
If in case you require TC console software for custom layouts for SX80, C40, C60 and C90 codecs, it can be downloaded from the following link:
Radhika Sajan
06-13-2016 04:01 AM
Actually custom layouts aren't supported on the C40 either, it's only supported on the C60/90 and SX80. I had initially had C40 listed in my earlier reply, but that was a typo and meant to be the C60 which has since been corrected.
06-13-2016 03:55 AM
It's not possible to create layouts on the SX20, you can only do this on the C60/90 and SX80 (running TC software).
03-13-2020 03:46 AM
we r not able to change layout of sx20 its show error no additional layout available
@sbahutale1 wrote:I just want to add layouts in SX20 manually...Is this possible???
