Can you configure the outputs from codec C-60?
Jose Ramon Saus
Hello There
I got a C-60 dual display  with two led displays. May I change the configuration of the ouput signals from codec. the problem is that I got the same image but with diferent colors on my room.
mubakhta
Level 4
Level 4
Hi Jose,
Are you seeing the same type of colors when on Presentation or when anything is displayed on the second screen. We want to verify if the second screen is showing these colors no matter what.
I want to isolate if the issue lies with the port or the configuration.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
