08-06-2013 10:39 AM - edited 03-18-2019 01:34 AM
We are running a little older version of the Tandberg TMS (12.6). It uses OpenDS. Problem is that the person that installed it, and configured it, and administered it, has left the company. If we disable his AD account, and try to add new users to a security group and then try to sync that group in provisioning in TMS, it will not get the new users. If we re-enable his account, then try to sync again, it imports the users accounts in and they can use movi/jabber. Trying to figure out where he username could be set. I checked in the Active Directory section in Network settings, and it has our service account. Any idea where his account could be where it is keying off it to import new users successfully?
TIA
08-06-2013 05:11 PM
It's been a little while since I've touched a version of TMS that is using TMS Agent Legacy as it's now called, but I'd advise to check the following guide, page 20.
I'd also looking into update your version of TMS to 14.x and upgrade to TMSPE to replace the old TMS Agent that uses OpenDS.
08-06-2013 05:14 PM
When importing users from AD for Jabber accounts, you use a different page, you should check the provisioning directory page. In TMS 12.6, I guess this page is located in System >> Provisioning >> Directory. Take a look at the session External Source Configuration, you will find the credentials used to import users from AD.
I hope this help.
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
