Cant stop Codian from showing Hostname for Dial-In participants
toby.lewis
Hi, I have an 8510 blade and if you dial in to it from an endpoint registered to the same VCS Control, it always shows the actual hostname of the 8510 blade as the destination/connected party on the screen. I dont want it to show this, I want it to show H.323ID, or the SIP ID of the conference, and I dont want to remove the hostname from the Network settings.
If you dial out from the MCU the participants see the H.323 ID, which is fine, If you dial in from the VCSexpresway you only see the SIP ID returned to you which is also fine.
Does anyone know how to change this without removing the Hostname, or making the call a traversal call so the Hostname gets hidden?
T
Patrick Pettit
Hi Toby.  Can you list the code versions your running in this setup? MCU, endpoints, VCS etc? Just want to gauge what your running to see where I may need to start.
VR
Patrick
