CDP Mode Problem
I recently changed some setting on our devices. CDP was on of those setting I changed from on to off. I've notice when changed on SX 80. I have no HTTPS response afterward. I'm unable to log into device.  Below are the setting that I changed. Hopefully it helps. I didn't include the ip address in the api
Note: On DX 80s', I don't have this issue.
xconfiguration conference Encryption mode:on
xconfiguration conference MaxReceiveCallRate: 3072
xconfiguration conference MaxTotalReceiveCallRate: 3072
xconfiguration conference MaxTotalTransmitCallRate: 3072
xconfiguration conference MaxTransmitCallRate: 3072
xconfiguration conference AutoAnswer Delay: 0
xconfiguration conference AutoAnswer Mode: off
xconfiguration conference AutoAnswer Mute: off
xconfiguration conference DefaultCall Rate: 3072
xconfiguration conference FarEndControl Mode: off
xconfiguration conference FarEndControl SignalCapability: off
xconfiguration HttpClient AllowHTTP: False
xconfiguration HttpClient AllowInsecureHTTPS: False
xconfiguration HttpClient Mode: off
xconfiguration HttpClient UseHttpProxy: off
xconfiguration HttpFeedback TlsVerify: off
xconfiguration HttpFeedback UseHttpProxy: off
xconfiguration Logging CloudUpload Mode: off
xconfiguration Logging Debug Wifi: off
xconfiguration Logging Internal Mode: On
xconfiguration Logging Mode: On
xconfiguration network 1 DNS DNSSEC Mode: off
xconfiguration network 1 DNS Domain name:
xconfiguration network 1 DNS Server 1 Address: xx.xx.xx.xxx
xconfiguration networkservices CDP Mode: off
xconfiguration networkservices H323 Mode: on
xconfiguration networkservices SIP Mode: on
xconfiguration networkservices Websocket: off
xconfiguration networkservices WelcomeText: on
xconfiguration networkservices XMLAPI Mode: on
xconfiguration networkservices SNMP CommunityName: usarc
xconfiguration networkservices Mode: off
xconfiguration networkservices SSH AllowPublicKey: off
xconfiguration networkservices SSH HostKeyAlgorithm: RSA
xconfiguration networkservices SSH Mode: on
xconfiguration networkservices Wifi Allowed: false
xconfiguration networkservices Wifi Enabled: false
xconfiguration phonebook server 1 id:default
xconfiguration phonebook server 1 Pagination: enabled
xconfiguration phonebook server 1 TlsVerify: off
xconfiguration phonebook server 1 type:TMS
xconfiguration phonebook server 1 url:
2 Accepted Solutions
Figured out the issue. Turning off CDP mode shut off the IP address of the system.
It would not shutdown the IP address as such, but the system would not get information from the switch to know what VLAN it is situated in as that is carried in CDP.
Response Signature
Response Signature
Thanks you for your response. I figured it out after doing some research on CDP, which I had no idea about. I'm appreciative that you explain it simple and to the point.
