CE9.2.1 Macro Framework with Touch 10
mmhm
Anyone can tell me why my button action is not working for this macro code ? I have added a button with Id 'callCatering' and added this macro. But I keep pressing that button which I have created in UI Extensions configuration. But no call is coming.
const xapi = require('xapi');
const number_to_dial = '8771';
function listenToGui() {
xapi.event.on('UserInterface Extensions Widget Action', (event) => {
//console.log('event', event.WidgetId);
if (event.WidgetId == 'callCatering'){
xapi.command('Dial', {'Number': number_to_dial});
listenToGui();
However, if I use this following macro code as soon as I am saving, I am getting the call.
asri.zainal
Try adding event type like below:
if (event.WidgetId === 'callCatering' && event.Type === 'clicked'){
I tried that. But click the button is not doing anything.
davisjaron
Let's try this.
Use this for your javascript file:
xapi.event.on('UserInterface Extensions Page Action', (event) => {
if(event.Type == 'Opened' && event.PageId == 'callCateringPage'){
xapi.command("dial", {Number: number_to_dial});
Now use this for your XML file:
<Extensions>
<Version>1.5</Version>
<Panel>
<PanelId>callCateringPanel</PanelId>
<Type>Home</Type>
<Icon>Handset</Icon>
<Order>1</Order>
<Name>Call Catering</Name>
<Page>
<Name>Dialing</Name>
<Row>
<Name>Row</Name>
<Widget>
<WidgetId>callCateringWidget</WidgetId>
<Name>Number is being dialed</Name>
<Type>Text</Type>
<Options>size=4;align=center;fontSize=normal</Options>
</Widget>
</Row>
<PageId>callCateringPage</PageId>
<Options>hideRowNames=1</Options>
</Page>
</Panel>
</Extensions>
Have a look at the Speed Dials example on github.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
