07-17-2019 12:45 AM
Hi all, during the meeting, some users can change the setting of volume, camera, LCD... on touchpad, so I want to reset all the settings on the touchpad as default after the meeting end, any idea for event listeners? I use Zoom room on the cisco. I also see Room Reset sample code but when I applied it, it did not run anything. Thank you.
Solved! Go to Solution.
08-21-2019 08:26 PM
At a quick look at your code, you have nothing that will trigger the reset.
You likely want a combination of @Lawrence James's code and yours.
Something like:
xapi.event.on('CallDisconnect', (event) => { if(event.Duration > 0) { xapi.command('Audio Volume SetToDefault'); xapi.command('RoomPreset Activate', { PresetId: '1' }); xapi.config.set("Video Output Connector 1 MonitorRole", 'Auto'); xapi.config.set("Video Output Connector 2 MonitorRole", 'Auto'); } });
Then, when the call disconnects, your room settings will be applied.
This also assumes that you're not using Multisite on the endpoint, as this will trigger on any call disconnect event (ie even if the endpoint is still in a call with other participants if only a single participant has been disconnected).
Please remember to mark helpful responses and to set your question as answered if appropriate.
07-18-2019 02:06 AM
There are a few options for this but you mentioned you tried the macro already so if that doesn't work there are a couple of steps required to allow Macros to run. First, the Macro Mode is Off by default so you need to turn that on -
xConfiguration Macros Mode On
Second, the runtime AutoStart needs to be on so after a reboot it starts this is On by default but check it to be sure.
Post the code to the Macro if the above steps were completed already as maybe there is something in the code that needs correcting/changed for your system. If you are using the Macro from the Git Hub site you would need to add an end of meeting status event to trigger the macro. I haven't used that macro but just looking at it doesn't have a status event to trigger it to run
something like
<<Room Change Code Goes Here - Less than second do nothing>>
else
<<Room Change Code Goes Here>>
08-18-2019 09:38 PM
08-21-2019 08:26 PM
Something like:
08-22-2019 11:49 PM
