02-22-2018 02:55 AM - edited 03-18-2019 01:53 PM
We have recently upgraded an MX200 from TC7.3.6.ea51021 to CE 9.2.3 3ba381b, since the upgrade the endpoint is showing a warning regarding a Certificate Expiry : A certificate has expired 17584 days ago. Please, update. I am not aware of any certificates that would need updating. The endpoint appears to be functioning as expected.
03-02-2018 09:53 PM
I also encountered the same warning when upgrading to CE9.2.3.
“WARNING: Certificate Expiry
A certificate has expired 17593 days ago. Please, update”
03-03-2018 04:04 AM
05-18-2018 05:29 AM
Is there a bug number for that error?
05-18-2018 06:31 AM
05-18-2018 06:44 AM
Thanks Justin. Could not find it. Searched on Certificate expiry, for MX800, nothing came up.
What was your method?
05-18-2018 06:50 AM
05-19-2018 11:28 PM
HI @Kieran Gilbert , @John F, @Song Yi,
Yes, it is a known defect and the bug-ID is : CSCvg46418
The one mentioned by @JFerello is also correct as CSCvh75103 is a duplicate of bug CSCvg46418
Workaround :This diagnostic warning is cosmetic only and may be ignored. The default self-signed certificate is valid for 20 years so any endpoint that is manufactured or factory reset after January 1, 2018 will show this incorrect diagnostic.
Fix : This issue has been resolved in latest firmware CE 9.2.4 (and beyond).
As CE 9.2.4 is deferred, you can download CE 9.2.5 from here for SX20, MX200/300G2 :
https://software.cisco.com/download/home/284091229/type/280886992/release/CE9.2.5
Rishabh Gupta.
Please rate the response if found helpful and mark as a solution if appropriate.
