Change Edge 95 resolution to work with TV
abdijbhat
Got a new Edge 95 and connected per User Manual. However, i always get "No Signal" error. I suspect it to be a resolution issue since i had to make tweaks for another hardware (an android box) to make it work. The question i have is, How to change the resolution on the Edge 95 box so that it works with the TV.
If resolution is not the issue, how do i make the Edge 95 work with the TV?
Warm Regards,
Abdij Bhat
PJMack
Level 7
Level 7
I hate to tell you this but your "new" Edge 95 is at least five years old since Cisco stopped selling them in 2013. End of support is May 31 this year.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-system-edge-mxp-series/end_of_life_notice_c51-720894.html
That said - to your problem, what output port are you using to connect to the TV? If it's the DVI port you can change the resolution - take a look at page 106 in the API guide:
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/mxp-series/f9/api_reference_guide/mxp_codec3000-6000_api_reference_guide_f90.pdf
Video Outputs DVIResolution Value space [1..x]: <Auto/SVGA/XGA/w720p/WXGA>
x = 2 on 6000 MXP x = 1 on 3000 MXP
Defines resolution for the supported DVI outputs.
Auto: VGA output format will be optimized depending on the video source format, refresh rate and of the EDID information available.
Example: xconfiguration video outputs dviresolution 1: auto
Hope this helps!
