Changing DefaulCallRate through CUCM
Hi!
We have recently changed the settings for videoconferencing to register with CUCM.
We currently have a compliance service that verifies that all equipment is set to a certain standard.
It turns out that whenever we register a videoconference (independent of the model) in the CUCM, the value of the DefaultCall Rate is changed to 6000
I searched in several places and did not find where to change this value in CUCM so that it stays in the value that we want.
Can you help me?
Jonathan Schulenberg
Generally speaking, you control per-call bandwidth of CUCM-registered endpoints using Regions within CUCM. Be aware that there are also Service Parameters governing the default bandwidth if you don’t define it at the Region level.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/cac.html
