Changing EMP IP address
zakaria.hadj
Hi, I need to change both MCU and EMP IP address. I lost the serial cable and I was wondering how can I change EMP's IP address?
Thanks in advance
ecarabias
Connect via telnet. If you don't have a prompt press Ctrl+C. For seeing the configuration menu execute the command modifyTargetDevice (case sensitive). When you exit the menu the EMP reboots.
Hope it helps!
ecarabias
Hope it helps!
It's working perfectly.
I'm very grateful.
Worked for me too!  Thanks so much.
