Check CPU Usage in MCU MPS
Dear Sir,
I have MCU MPS 800 and Gatekeeper in our vcon network, i want to know of CPU usage on that device.
which command and how can i get it ? please for feedback and ur reply for this.
Thanks&Gbu
11 Replies 11
Hi Nanda,
I did not find any this information in the Web GUI or the CLI in the admin account.
You could login to the MPS using root account and check the CPU utilization using the 'top' command.
Hope this helps.
Shilpa
Dear Shilpa
Thanks for ur Suggestion Mr Shilpa, its helful
i found the log like this,
On The CPU usage is very high,
Please tell me the reason why CPU usage ha very high.  and how about the solution for this issue,
Thanks very much for ur attention
Best Regards,
  255 root     S       185M   246  3.9 74.1 tabsc.elf
10754 root     R       1060 10751  0.3  0.4 busybox
10736 root     S       1884   175  0.1  0.7 sshd
  256 root     S       185M   246  0.0 74.1 tabsc.elf
  266 root     S       185M   246  0.0 74.1 tabsc.elf
  260 root     S       185M   246  0.0 74.1 tabsc.elf
  253 root     S       185M   246  0.0 74.1 tabsc.elf
  254 root     S       185M   246  0.0 74.1 tabsc.elf
  258 root     S       185M   246  0.0 74.1 tabsc.elf
  274 root     S       185M   246  0.0 74.1 tabsc.elf
  248 root     S       185M   246  0.0 74.1 tabsc.elf
  272 root     S       185M   246  0.0 74.1 tabsc.elf
  270 root     S       185M   246  0.0 74.1 tabsc.elf
  245 root     S       185M   240  0.0 74.1 tabsc.elf
  251 root     S       185M   246  0.0 74.1 tabsc.elf
  252 root     S       185M   246  0.0 74.1 tabsc.elf
  273 root     S       185M   246  0.0 74.1 tabsc.elf
  249 root     S       185M   246  0.0 74.1 tabsc.elf
  261 root     S       185M   246  0.0 74.1 tabsc.elf
  250 root     S       185M   246  0.0 74.1 tabsc.elf
  246 root     S       185M   245  0.0 74.1 tabsc.elf
  247 root     S       185M   246  0.0 74.1 tabsc.elf
  257 root     S       185M   246  0.0 74.1 tabsc.elf
  259 root     S       185M   246  0.0 74.1 tabsc.elf
  262 root     S       185M   246  0.0 74.1 tabsc.elf
  263 root     S       185M   246  0.0 74.1 tabsc.elf
  265 root     S       185M   246  0.0 74.1 tabsc.elf
  271 root     S       185M   246  0.0 74.1 tabsc.elf
  215 root     S       1732     1  0.0  0.6 snmpd
  175 root     S       1140     1  0.0  0.4 sshd
10751 root     S       1040 10736  0.0  0.4 sh
28563 admin    S        944 28554  0.0  0.3 tshell
Mem: 231104K used, 24772K free, 0K shrd, 1160K buff, 30456K cached
Load average: 0.71, 0.64, 0.63    (State: S=sleeping R=running, W=waiting)
  PID USER     STATUS   RSS  PPID %CPU %MEM COMMAND
  201 root     R        664   196 96.0  0.2 busybox
  255 root     S       185M   246  3.3 74.1 tabsc.elf
Load average: 0.66, 0.63, 0.62    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 94.6  0.2 busybox
  255 root     S       185M   246  3.5 74.1 tabsc.elf
  256 root     S       185M   246  0.1 74.1 tabsc.elf
  150 root     S        776     1  0.1  0.3 logrotate
10864 root     S        552   150  0.1  0.2 busybox
Load average: 0.68, 0.64, 0.62    (State: S=sleeping R=running, W=waiting)
  255 root     S       185M   246  3.7 74.1 tabsc.elf
  256 root     S       185M   246  0.5 74.1 tabsc.elf
10866 root     S        552   220  0.1  0.2 busybox
Load average: 0.81, 0.67, 0.63    (State: S=sleeping R=running, W=waiting)
  255 root     S       185M   246  3.1 74.1 tabsc.elf
10754 root     R       1060 10751  0.5  0.4 busybox
10868 root     S        552   220  0.1  0.2 busybox
10736 root     S       1884   175  0.0  0.7 sshd
Load average: 0.83, 0.67, 0.64    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 95.8  0.2 busybox
Load average: 0.84, 0.68, 0.64    (State: S=sleeping R=running, W=waiting)
  150 root     S        776     1  0.3  0.3 logrotate
Load average: 0.77, 0.67, 0.63    (State: S=sleeping R=running, W=waiting)
Load average: 0.71, 0.66, 0.63    (State: S=sleeping R=running, W=waiting)
Load average: 0.73, 0.66, 0.63    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 95.6  0.2 busybox
10754 root     R       1060 10751  0.7  0.4 busybox
Load average: 0.75, 0.67, 0.63    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 94.2  0.2 busybox
10902 root     S        552   150  0.1  0.2 busybox
Load average: 0.77, 0.67, 0.64    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 95.0  0.2 busybox
  255 root     S       185M   246  4.3 74.1 tabsc.elf
Load average: 0.65, 0.65, 0.63    (State: S=sleeping R=running, W=waiting)
Load average: 0.68, 0.66, 0.63    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 95.2  0.2 busybox
Load average: 0.63, 0.64, 0.63    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 94.8  0.2 busybox
Load average: 0.58, 0.63, 0.62    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 95.5  0.2 busybox
Load average: 0.53, 0.62, 0.62    (State: S=sleeping R=running, W=waiting)
  201 root     R        664   196 95.4  0.2 busybox
Hello Nanda
Looks like someone executed busybox command which can be process intensive.
You can use history command to see what commands were run before.
Also you can check this admin and api guide for your MPS box:
http://www.cisco.com/en/US/docs/telepresence/endpoint/mps/j4/administration_guide/tandberg_mps_administrator_guide_j46.pdf
http://www.cisco.com/en/US/docs/telepresence/endpoint/mps/j4/api_reference_guide/tandberg_mps_api_reference_guide_j46.pdf
Cheers
Rafal
Definitely busybox shows high CPU utilization level and this is not normal level.
Do you have any other session on MPS and running ping or other operation by API?
Do you see same CPU utilization by busybox even restart MPS?
If so, I suggest to take sniffer log on MPS (sniffer incoming/outgoing packet on MPS by using mirror port configuration on switch).
Hello colleagues,
I have the same problem with the process "busybox".
Has anyone tested the kill -9 PID?
Did you have any problem with the MPS 800 after performing the command?
  199 root     R        712   194 71.2  0.2 busybox
  253 root     S       185M   244 29.5 74.3 tabsc.elf
  254 root     S       185M   244  6.2 74.3 tabsc.elf
 3036 root     R       1064  3018  0.9  0.4 busybox
  264 root     S       185M   244  0.7 74.3 tabsc.elf
 2316 root     S       1064  2309  0.5  0.4 busybox
  234 root     S        464   228  0.3  0.1 pci_fs_server
  258 root     S       185M   244  0.1 74.3 tabsc.elf
  251 root     S       185M   244  0.1 74.3 tabsc.elf
 5029 root     S        552   218  0.1  0.2 busybox
  252 root     S       185M   244  0.0 74.3 tabsc.elf
  246 root     S       185M   244  0.0 74.3 tabsc.elf
  249 root     S       185M   244  0.0 74.3 tabsc.elf
  298 root     S       185M   244  0.0 74.3 tabsc.elf
  256 root     S       185M   244  0.0 74.3 tabsc.elf
  294 root     S       185M   244  0.0 74.3 tabsc.elf
  250 root     S       185M   244  0.0 74.3 tabsc.elf
  296 root     S       185M   244  0.0 74.3 tabsc.elf
Franklin
Hy mr rafal,
i tried check with xhistory command, there is no
what can i kill or disable busybox command ?
and what the effect if i ignore this busybox command ?
thankyou sir
Hey Nanda
You can try stop busybox by:
kill (ppid)
or
kill -9 (ppid)
or by name
killall -9 busybox
Rafal
Tomonori Taniguchi
Dear Mr Tomonori,
i have error, when i try to see erorr in MCU .
like this.
Mem: 231428K used, 24448K free, 0K shrd, 1160K buff, 30476K cached
Load average: 0.85, 0.80, 0.69    (State: S=sleeping R=running, W=waiting)
201 root               R        664    201         95.6    0.2           busybox
dan 201 itu
201 root        664 R   telnetd -P /var/run/telnetd.pid -l /bin/login -r -L 10.2.156.3
and
~ # pcpu,pid,user,args | sort -r -k1 | less
-sh: pcpu,pid,user,args: not found
sort: invalid option -- k
BusyBox v1.00-pre7 (2009.04.21-11:34+0000) multi-call binary.
Please, can you explain about that log sir ?
how can i check  running ping or another operation in our MCU ?
Thankyou Mr Tomonori,
Best Regards,
Nanda
Rafal Szeremeta
Hey Nanda
kill (ppid)
or
kill -9 (ppid)
or by name
killall -9 busybox
Rafal
Dear Mr Rafal
Is There any effect or problem if i kill that process sir ?
how can i rollback and run that process again ?
Thankyou very much sir,Gbu
Best Regards,
Nanda
Do you know what is 10.2.134.122?
Does MPS System Controller Blade configure IP address on both Interface 1 and Interface 2?
BTW, what is software version running on MPS?
Dear Mr Tomonori
I'm Sorry , that's is My IP while open the root session
My MPS System Controller Blade configured just interface 1.
and the software of my MPS is J4,6 sir.
i have strange log when i use "top" command in our MPS.
i see in % CPU usage until 1100,0. its true 1100,0 or i just wrong translate this ? sometimes 98,8 . its not stable
There is any bug ?
Best Regards,
Nanda
