Check if TMS phonebook is reachable from codec
segrana
Hi all,
I'm starting a new telepresence setup. I have problems with the phonebooks. Seems that codec are not even trying to search the TMS phonebook.
How can I check if the codec is configured to query the TMS phonebook?
In "Advanced Configuration -> Phonebook Server 1" ID is set to default, Type to TMS and URL to http://<TMS IP>/tms/public/external/phonebook/phonebookservice.asmx
When the users press the phonebook key in the remote, nothing us shown, only My Contacts.
Thanks for the update - the issue is usally a proxy or firewall - Your endpoint(s) need to have direct access to port 80 on the TMS box from the subnet they're on.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
16 Replies 16
Patrick Sparkman
Hello segrana -
Have you applied any phone books to the codecs within TMS?
If you haven't already applied phone books to the codec, you can do so either of the following ways:
  • In TMS, go to Phone Books > Manage Phone Books.
    1. Select the phone book you want to apply to the system, and select "Set On Systems".
    2. In the left column choose the codecs you want and click the right arrow > to select it.
    3. Click "Save" when done.
  • In TMS, go to Systems > Navigator.
    1. Select the codec you want to apply the phone book to, and select "Phone Book".
    2. In the left column choose the phone book you want and click the right arrow > to select it.
If you have SSH access to the codec, you can view debug logs and see what's happening:
log output on
log ctx phonebook debug 9
Hi Patrick,
Yes, I had already applied the phonebook to the codecs. The Phonebook is called MDP and is the onlyone. Is the default one that I renamed it.
The log is only showing this:
32834.88 TMS I: provision(): http request url/http:///tms/public/external/management/systemmanagementservice.asmx/785 bytes
32834.89 TMS !ER http(this=0x481f75a0): failed with (No error)
32834.89 TMS I: provision(): tms query FAILED, length 1293
Can your codec reach the TMS server?  You can do a ping from the codec if you have root access.
Do you have your TMS set to use HTTPS or HTTP for system communication?
  • Administrative Tools > Network Settings > Secure-Only Device Communication
    • Off = HTTP / On = HTTPS
I can reach the TMS from the network where the codec resides, I don't know how to check form the codec cli.
Secure-Only Device Communication is Off.
xcommand Phonebook Search list is empty
OK
*r ResultSet ResultInfo TotalRows: 0
** end
Thanks!
Might be a silly question, but it might be worth checking - where it says in the URL string (http:///tms/public/external/phonebook/phonebookservice.asmx) are you actually putting in the IP address of your TMS Server?
You don't mention which codec you are using - if it's one of the newer ones, you can log on as root and issue the "curl http:///tms/public/external/phonebook/phonebookservice.asmx" command (again, with the actual IP address of your TMS server in place of - this will return you some HTML back that you should be able to see if it's getting to your TMS server, or hitting a proxy or firewall issue in the way somewhere.
Wayne
Wayne
Hello Wayne,
Yes, is the actual IP address.
These are C40 and SX20.
How can I login as root?
Thanks!
You will need to "ssh" or "telnet" in to the codec (try downloading and using PuTTY if you haven't already got it) to get to the command line interface.
You can then log in as root.  (although you may need to enable it first by logging in as admin and issuing the "systemtools rootsettings on" command).
This will give you a command line prompt where you can issue the above curl command.
Wayne
Wayne
Access denied:
http://www.w3.org/TR/x
        html1/DTD/xhtml1-strict.dtd">
http://www.w3.org/1999/xhtml
401 - Unauthorized: Access is denied due to invalid credentials.
You do not have permission to view this directory or page using the creden        tials that you supplied.
Should I have to disable Basic and Windows Authentication in the public virtual directory? Anonymous is already enabled.
Thanks!
Sounds similar to an issue one of the other forum users had a while ago.
There's some more troubleshooting information in this thread: https://supportforums.cisco.com/message/4124552
Wayne
Wayne
In my case, when browsing from a PC the site is displayed correctly.
I disabled both basic and windows authentication with no luck.
What if I configure user and pass in the provisioning tab in the codec? Will that help?
Thanks!
Ok, I found that on two endpoints it is working fine. Strange.
I will go ahead and purge the devices that are not working and add them to the database again after that.
Thanks!
It could be a firmware version difference between the ones that work and those that don't too... what versions are each of the codecs running?
Wayne
Wayne
I've checked and firmware is the same on all of them TC5.1.3.292001.
I found that the problem is in a single subnet. From a server in that subnet, browsing to the phonebook url asks for user and password, so the problem is in some device in between.
Will check and keep posting.
Many thanks for all your help!
Wayne
Wayne
