Cisco C20 endpoint showing incorrect time
paullfender
HI Team,
We have a strange issue with Cisco Codec C20, that seems to have happened following an upgrade to  software release TC7.3.15.a9f4c3a
The On Screen Display is showing the wrong date & time, however we have NTP configured and synced. From command line, we can see that the NTP server is specified and polling, and the date / time are correct.
systemtools ntp
remote             refid            st t when poll reach delay offset jitter
*10.82.10.250 169.254.0.1 4 u 12 16 377 28.362 0.021 7.845
127.127.1.0 LOCL 10 l 813 16 0 0.000 0.000 0.000
Current time in UTC is: Wed Jun 12 01:22:54 2019
Current time in AEST is: Wed Jun 12 11:22:54 2019
xcommand systemunit datetime get
OK
*r DateTimeGetResult (status=OK):
Day: 12
Hour: 11
Minute: 44
Month: 6
Second: 54
Year: 2019
however on the On Screen Display it is showing the incorrect date and time
has anyone seen this issue before? any help would be appreciated
Paul
Have you got both the correct "OlsonZone" and "Zone" set for the Time in the Configuration?  ie, for here in Adelaide:
xConfiguration Time OlsonZone: Australia/Adelaide
xConfiguration Time Zone: GMT+09:30 (Adelaide)
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
HI Wayne,
thanks for the reply. Yes both OlsonZone and Zone are set correctly
xconfig time
*c xConfiguration Time DateFormat: DD_MM_YY
*c xConfiguration Time OlsonZone: Australia/Sydney
*c xConfiguration Time TimeFormat: 12H
*c xConfiguration Time Zone: GMT+10:00 (Canberra, Melbourne, Sydney)
Might be a dumb question, but have you turned it off and on again?  Does a reboot fix the time, or is it consistently out?  Is it out by a consistent amount?  Any reason you aren't running the latest software release (TC7.3.17)?
Wayne
