Cisco CME VG202 Call Forward
bodo.kaiser
Hey,
i have a FAX with Voice Gateway VG202 , it works with this config on the CME :
dial-peer voice 21 voip
destination-pattern 12
no modem passthrough
session target ipv4:192.168.166.4
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
Now the Problem, i would like a Call Forward Nuumber to the other Fax .
I don't have the config for this and no Idee .
Please help me
bodo.kaiser
Hey,
i install the voice-translatin rule for this Fax number and it works !
Have you a other idee ?
You can configure the port as SCCP device and configure "call-forward all" under then ephone-dn that ssociated.
