Cisco CMS 3.3.6 Recording
scr.sybex1
I have VQ Manager, 2 * CMS Server 3.3.6, 1 * CMM and a CMS 3.3.6 Server that recording Component is configured.
the problem that i have is that after integrating cms with vq, the recording is not working anymore. don't know what should be the problem. i couldn't enable recording through web app.
all outbound rule and recording uri is configured correctly.
attached the log file,
appreciate if someone could help me to find the solution
b.winter
looks like, the call cannot be established:
2021-11-22 12:47:31.573 Info call 32: outgoing recording SIP call to "recorder@recorder" from space "rezaei.mohammad"
2021-11-22 12:47:31.573 Info call 32: configured - API call leg 86d44c83-1d49-4f08-bb1e-73b8ca8de116 with SIP call ID "07dc931f-5ff0-4121-8082-d38cf1b9a3c9"
2021-11-22 12:47:31.576 Info call 32: setting up UDT RTP session for DTLS (combined media and control)
2021-11-22 12:48:03.573 Info call 32: ending; local SIP teardown with reason 7 (transaction timeout - no provisional responses sending INVITE) - not connected after 0:32
2021-11-22 12:48:03.573 Info call 32: destroying API call leg 86d44c83-1d49-4f08-bb1e-73b8ca8de116
Why do you use the URI "recorder@recorder" without the domain part (e.g. "recorder@recorder.com")?
How have you configured the outbound rule for the recorder?
Thanks for replying,
yes as i said i configure the outbound rule with "recorder" domain part sending the call to CMS Recorder sip proxy server.
but as you said the call not connected.
configuration is the same as the following documentation, and i don't think that .com would solve my problem. because the document configured the parameter like that.
https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server-1000/216184-how-to-configure-recorder-service-in-cis.html
Can you make a screenshot of the outbound rule?
Can you make a screenshot of the CMS recording config (just use the command "recorder")?
What do you see in the logs of the recording CMS?
Ammar Saood
Try configuring your outbound rule on CMS to unencrypted (assuming you're not using an encrypted deployment)
also try to turn off call optimization on VCS if VCS is your next hop.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs56702?rfs=iqvred
Please rate & click "accept as solution" if this answered your Question.
