Cisco Codec Pro - Power Usage
JesseJames7761
Looking for power usage of the cisco codec pro. In the datasheet and admin guide it only states
Autosensing power supply
• 100–240Vac, 50/60Hz
I require typical power consumption in watts. Someone please assist.
●  100 to 240 VAC, 50/60 Hz, 12V DC input
●  Standby 6W, average 20W, peak 70W
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
You can check below link to get the exact power ratings.
PDF PAGE : 18 section H. for codec pro.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/room-kit/installation-guide/codec-pro-installation-guide-en-fr-es-pt-it-de.pdf
You can calculate the volts to AC by checking this post.
https://www.voltagevalet.com/pages/modifying-electricity
Please rate my response.
Agree with this post.
Incorrect.  This is for the Quad Camera Only.  In the Install manual on p16, it says the CODEC's power is 1.3A at 110V and .6A at 240V.  We can calculate about 143 Watts power consumption for the CODEC Pro by itself.
