Cisco Meeting Server 3.0 not able to configure Webbridge3 service using Self-Signed Certificate
In Cisco Meeting Server 3.0 Version, I'm not able to configure the Webbridge3 Service in CMS CLI using the Self-Signed Certificate.
Kindly help us to resolve the issue.
Navinkumar S
6 Replies 6
Use a CA signed certificate,
an external CA is not required use ur internal CA.
Response Signature
As per your suggestions, we can't do it with a Self-signed certificate right?
Navin Kumar S
Self singed is recommended for test scenario.
Response Signature
Hi Navin,
As currently tested with my own CMS, I think you have to add the CN manually when generating the self-signed cert.
e.g. pki selfsigned <tag> CN:cms.test.com
This CN has to be in the API command, when you add the webbridge3:
POST to https://<ip-or-fqdn>:<port>/api/v1/webbridges
Parameter: url --> c2w://<Webbrige 3 CN>:<Port>
The IP / FQDN of the above url has to be in the certificate (which you assign via CLI command "webbridge3 c2w certs <key> <cert-chain-file>")
But even if you have the CN in the cert, the connection won't establish with the following error:
C2W Peer 7FE8E88A2200 failed TLS handshake with error: self signed certificate
I hope, that helps.
b.winter
Hey,
what's the issue you are having?
You get any error messages? Can't you enter any commands? ...
Best regards
Hi Navin
Did you get to resolve this? Could you please share the config as I am using self signed certs as well? Thanks
