Cisco Meeting Server Cluster Upgrade to 2.3.6
Steffen Wentzel
Hi team,
currently I'm planning to upgrade a CMS cluster from 2.3.0 to 2.3.6. The cluster consists of three nodes, all are virtualized deployments. We have two callbridges and one dedicated DB node:
  • CMS01: CallBridge + DB
  • CMS02: CallBridge + DB
  • CMS03: DB only
From the upgrade documentation I understand that I should issue a
database cluster status
command to check DB health and find out which nodes are slave/master. Then it says "Upgrade each database node, one by one, starting with the slave database nodes and finishing with the master node".
Q1: What are the database nodes in my case? I assume this includes all nodes in my case, b/c the DB service runs on all three nodes, correct? And the master/slave information is shown by above command, so it could be that (depending on current status) I'll upgrade even CMS03 first, is this also correct?
Then I should login to the DB master node and issue this command:
database cluster upgrade_schema
Q2: Is this command only required on the current master node? So this implies that it will upgrade the schema on the slave nodes automatically?
Thanks for your feedback!
BR
Steffen
Thanks Jaime, actually I haven't :-) Very helpful information, will do the upgrade today in the evening.
All the best,
Steffen
