CISCO MEETING SERVER LDAP 2.6.0
Chet Cronin
Level 4
Level 4
Have an issue.
We have our CMS LDAP configured and appears to be good but noticed we get the URI name but not a call id number ?
Any ideas how to get the CALL ID number assigned is appreciated.
We can manually create co spaces from CMS but no way to assign a call id number of a person who is on LDAP ??
Chet Cronin
Patrick Pettit
CMS 2.6 is quite an old version.   You may want to think of upgrading.
Anyhow, to answer the question, in the ldap setup, depending on where you set it up, in the Field Mapping Expressions on webadmin or in the ldapmappings in API, you can pick a field in ldap that is unique to setup a call id.  You can perhaps choose telephone number or something and populate those in as call ID's.  On the webadmin under Active Directory is Space Call ID and in API under /ldapmappings its coSpaceCallIdMapping.  If nothing is supplied there, then one would be auto generated in its place.  Surprising you are not seeing one with the Active Directory configured as its usually auto generated if these fields are left blank.  Hope this helps.
VR
P2
Patrick Pettit
VR
P2
thank you ... will look into that ..
Chet Cronin
Sorry for the long delay getting back to you.
Problem resolved.   It was filter settings ...
Chet Cronin
