cisco meeting server login_warning issue
chet581
Running CMS Version 2.9.3.
When I enter the login_warning which is only about 192 characters from notepad with multiple lines It returns only the first line.
Can't figure out what I am doing incorrectly.
Any assist is appreciated.
What I do is copy the text and past it in the MMP after entering login_warning add "text"
b.winter
you can't use the enter button while adding your text to be a linebreak, because the enter button confirms the command, like in every CLI.
You need to use \n to specify a line break:
E.g.: This is my first line\nThis is my second line
Or you prepare the text in an editor and save the file as "login_warning" (with no file extension!!) and upload it via sFTP to the CMS.
b.winter
Any update on this? Did my suggestions help?
Yes it worked .. thank you very much ..
Resolved.
Glad to hear that ':)'
Would appriciate it, if you can select one of my answers as a solution.
