Cisco Meeting Server SNMP documentation
Elter
Level 4
Level 4
Hello, there is a customer that want to proactively monitors the CMS/Acano virtualized server regarding its callbridge feature via SNMP.
Is there a documentation that explain all the traps sent by the CMS and its conditions?
Is there a documentation that explain the OIDs and its states for the NMS to connect and monitor?
Patrick Sparkman
Only SNMP documentation is in the CMS MMP Reference Guides, the MIBs can be downloaded from that same page as well.
Unfotunately the documentation was already verified before to post and it only indicates how to configure the CMS to work with SNMP. There is no information regarding OIDs and their possible states.
The MIB file can be uploaded to interpret the traps generated by the CMS, but we cannot find anywhere which are the OID traps (except the Description inside the MIB) and their status/triggers.  For example: Which are the OID for errors, warnings, etc, when to generate an alarm or action and if/when the condition is cleared.
I found this file:
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/MIBs/SNMP-MIB.txt
I think it may helps.
Gilmar Silva
