Cisco Meeting Server Space PIN timeout too fast
We have a CMS v2.2.8 installation with several spaces protected by PIN. The PIN input timeout is so fast that most users cannot make it in when dialing the space for the first 4 to 5 times, especially when dialing from a Webex Board. Therefore we need to set a longer timeout.
Most CMS config parameters can only be set via the REST API, so I dug a little in the related reference guide here:
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Reference_Guides/Version-2-2/Cisco-Meeting-Server-API-Reference-Guide-2-2.pdf
and found the possibility to set the value of /callProfile/passcodeTimeout.
My issue here is that I'm not able to set that parameter, either by creating a new callProfile or by trying to modify an existing one.
API access is working correctly and I can successfully create and delete callProfile notes using the POST and DELETE methods.
When I create a new callProfile with these parameters:
https://***:445/api/v1/callProfiles?passcodeMode=timeout&passcodeTimeout=20
I get a callProfile of:
<?xml version="1.0"?>
<callProfile id="5ab8c406-c6fb-4195-aac9-dcec2d5baa11"></callProfile>
Anyone having luck with this?
Thanks.
This bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh99946
States that the passcode input timeout is 60 seconds but we are experiencing a definitely smaller timeout. I'm puzzled.
Patrick Sparkman
You're probably hitting bug CSCvf79666, recommend you upgrade to CMS 2.2.10 or 2.3.1 or later.
Thank you, Patrick! Will try that.
