04-19-2016 07:33 AM - last edited on 03-25-2019 09:16 PM by ciscomoderator
Hi All,
I had try to use DX 80 registered to CUCM at external network through MRA.
But the quality is not good due to the bandwidth is only under 384 kbps.
I had set the device pool on CUCM 6M already, but not work.
Does anyone know how to adjust the bandwidth in my situation?
thanks all
04-20-2016 01:42 AM
You may try some suggestions as per the following post
https://supportforums.cisco.com/discussion/12436896/dx80-video-quality-poor
Manish
04-21-2016 09:13 AM
Hi Manish,
Thanks you firstly.
According to the post you suggestion, it is about region setting on CUCM.
But I had already set the region to 6M, and the internal video is good.
But how come the DX80 on external network through MRA is poor in quality. only 2xx kbps.
Is it the limitation on MRA?
Thanks all
04-22-2016 03:33 AM
There is no such limitation with DX80 and MRA about the bandwidth. Its most likely a QoS related issue where bandwidth is getting choked at some point in the call flow.
Manish
