Cisco Navigator Parts
peyton.gwinn
We don't use the CS-Touch or Navigator for controlling the codec in the room. Instead we use I third party integrator to control the codec through serial.
SO my question is, Can the CS-T10-WM-BR= be used to convert the CS-T10-TS+ to a CS-T10-WM-K9= ?
We could then use the navigator outside the room for room availability.
No you can't. You can use CS-T10-WM-BR on  CS-T10-WM-K9=.
CS-T10-TS+ is a table version.
Response Signature
So is there way to to order the Webex Room KIT PRO with the CS-T10-WM-K9= instead of the CS-T10-TS+?
I didn't see it as a configuration option.
CS-T10-WM-K9= need to order separately.
There is no bundled package and Cs kit with Room Navigator doesn't have option to select  Wall Mount version. Its not a common scenario.
Response Signature
