cisco room kit
RRamirez1
good afternoon I want to activate the option to take screenshots, but I can not find the option, I am entering the configuration through the IP webwebex,cisco room kit,
Vaijanath Sonvane
You need to navigate to Maintenance >> User Interface Screenshots.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Wayne DeNardi
If you want to be able to see what the cameras are seeing via the Call Control page on the web interface (as per your screenshot), then you will need to purchase and install the "Remote Monitoring" Option Key on to the device.
Once you have your option key to install, you install it via the web interface on the Maintenance > Option Keys page.  You will need to restart the device after adding the key to make it active.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
